koda2000
- September 2, 2011
- x
If it wont spin with the plugs out, it is likely you've bent the piston connecting rods when it hydro-locked. The reason I don't think the issue is your starter is because the lights go dim when you try to crank it. This indicates the starter is trying to turn the engine, but can't.
With the plugs out you can try putting a breaker bar on the harmonic balance bolt. If you can't turn it by hand, your engine is now a ball of junk... sorry.
