djpanfire
- September 24, 2008
- Port-au-Prince
- 97 Xlt 4wd
Really don't know what to do
My explorer when cold will start normally it will go to 2k RPM and go back down progressively to 1 or 1.1. The problem occurs when you try to accelerate the RPm will drop and it will go into a bubbluly state. If you let it warm up a bit it wont do it but it's obvious that I have a loss of power (can hear the valve clacking when I give to much pedal) and it will sometimes hesitate when changing gear.
Changed:
IAC
FPR
Coil Pack
Spark Plugs
Fuel Filter
Fuel Pump
Check and clean injectors
Intake Lower and Upper gasket (did overhall)
Seems top me like it just not getting enough gas I don't know help anyone
PS: Was working really fine after the overhall was done. After that it took one week for me to feel and notice the power decreas.
Changed:
IAC
FPR
Coil Pack
Spark Plugs
Fuel Filter
Fuel Pump
