I've been searching this forum for a few days looking for information on the P0401 insufficient EGR flow code my '96 Limited 5.0L AWD has. I've found a lot of good information but not enough to fix my problem. So far I've learned the common problems are:
- P0401 is most likely DPFE sensor problem
- Could be caused by broken/loose EGR tube
I've located my EGR valve and solenoid but I don't think my engine has a DPFE sensor or tube coming from exhaust to EGR valve. I've inspected the hose going from the solenoid to the valve and it's clean. I will use a vacuum tester on the valve tonight, but almost everything I've read on this forum says the valve is the least likely of the system to fail, so can you help me out with some other things to look at and troubleshoot before I start digging in tonight?
I know basically what the EGR system is and how it works but I've never had the opertunity to troubleshoot one before. Any help about my specifric application is greatly appreciated.
