Is it fair to assume it's because you have to work extra to get money so then you have no time cause you're always at work?
That seems to be how it goes. If you can ever make enough to do more than just live then you're stuck with never having any free time to spend the money you're making .
well
today and tomorrow morning I'm going to see if I can get my rock sliders foot step inserts completed to get another job out of the garage.
I picked up the metal from work that was being scrapped. and it seems to be just right for what I want to do with it.
so here is a preview of how it will look.
the front rods are drilled into the nerf bar to set them in place. the back toe stop as I like to call it will be a little lower after modifying it after this picture was taken. and they will be welded to the bar to keep it all in place.
I will mix up some J-B weld and coat the front rods before I install this for the last time and weld it in place to seal the holes and to keep them from rattling.
I was looking at using channel and just bolting it to the frame where need be.
Since the frame narrows towards the front that's the only thing I could thing of doing.
It's been lack of motivation/fear of drilling into the frame that has stopped me so far. I think conceptually it's not too hard though, right? Just bring out the brackets that attach to the frame til the bars are straight front to back; add flat stock for spacers as necessary.
