My battery in the 2011 was changed after about 1.5 years. It was replaced under the factory warranty. Not sure if a battery would cause the wrench light to come on especially when the engine is running.My wife was driving the day after we got our 2013 Explorer back from having the steering gear replaced and the dreaded wrench warning light came on and the car sputtered and she had to pull over on a busy road. Luckily when she restarted everything was fine...until it happened in the way home from work. When in the shop for the steering gear (3 weeks!!) the dealer mentioned I needed a new battery (after 2.5 years??). Could this be causing the problem? If so, I'll just change it out myself, otherwise I need to have it towed to the dealer..ugh. We just got it back
I have the exact issue with my 2012 Explorer. Happened twice. Did you ever determine what the problem was?I have a 2011 Explorer limited with 23500 miles about 2 weeks ago it started with a wrench light coming on over the tach. When it comes on you loose all throttle (no gas pedal at all NOTHING) when you hit OK for the wrench the tach comes back on and it is tach at 1000 rpm you give it the gas nothing. It will continue to roll until you put your foot on the break to stop it and if you release the break it will start rolling again. If you put it in neutral still no throttle control and still tacking at 1000 rpm. Shut it off and restart everything go back to normal. This has happen 3 day in a row, brought it to dealer they had it 1 week drove it 300 miles and it did not occur again. (Can't see can't fix) But the third time it happened I took a video which they have a copy of. But even with the video they still can't fix it because the COMPUTER did not give a code for turning the WRENCH ON.
I told the dealer that at Ford someone knows why the light came on. something turned the light on and disconnected the throttle code or no code.
After I got it back it happened again with my wife an now she has a video of it and I have told Dealer that I have it on video again. We are now weighting to see what the service manager is going to do next.
Has anyone else had a problem like this? I could not find anything on the site.
Welcome to the Forum Tim.I have the exact issue with my 2012 Explorer. Happened twice. Did you ever determine what the problem was?
Like Peter said, the OP hasn't been on for a long time, however, I did see he got it resolved with a new throttle body.
Check out post 11.
If this works, should bring you right to his resolution.
Wrench light 2011 Explorer
I have a 2011 Explorer limited with 23500 miles about 2 weeks ago it started with a wrench light coming on over the tach. When it comes on you loose all throttle (no gas pedal at all NOTHING) when you hit OK for the wrench the tach comes back on and it is tach at 1000 rpm you give it the gas...www.explorerforum.com
