BetchaCantRide
- May 2, 2002
- Orlando, Fl
- 2000 Sport 4x4
Okay, been searching all afternoon for a solution on here, and have narrowed things down to what seems to be a very strange problem....
after lunch today, went to start the X, and turned over very strong, but no start. I've narrowed the problem down to the OBD/fuel injectors:
-getting fuel and pressure to fuel rail; pump/relay/FPR are all good
-getting a good spark
-voltage is good
For the fuel injectors to operate properly, they need to receive a 'pulsing' voltage from the computer that cycles w/ the firing order of the engine. Well using a voltmeter on the injector connectors, it seems that they are getting a steady voltage rather than the pulsing one, which keeps them from injecting fuel into the combustion chamber properly.
I need to know if there is a sensor or something else that might 'cause the injectors not to work properly. I've tried reseting the computer, but have had no success. I need this vehicle for work, so good suggestions ASAP would be greatly appreciated!
THANKS
-voltage is good
THANKS
