kcosh
- January 28, 2014
- South Jersey
- 2002 Ford Explorer xls
Bought 02 XLS with a trans problem code 0775 would appear with accompanied with the OD light blinking, no overdrive and had to shift 1st to second by letting off the pedal - so far pretty normal right? I adjusted the bands and voila!, shifts good and now there is overdrive.
Well just recently after a few weeks of feeling confident, I started to hear a whining sound when decelerating and after a couple of days, shifts started to get sloppy 4th and 5th(Overdrive) started toggling back and forth.
Now the whining is accompanied by grinding and the blasted blinking light is back.
Thinking it was the diff. I changed the oil and also in the transfer case - no change, just getting worse. Also noticed leak at front differential.
Could this be a differential coincidence and I should start looking at the front diff. or should I just wave the white flag on the tranny.
