Now that I've decided that if I significantly increase the power in my 2000 Sport I will install a V8 I need to consider engine possibilities. I'm not very knowledgeable about Ford V8s since my Sport is the first Ford I've owned.
Of course the easiest would be the 302/5.0L since it came stock in so many of the 4 door Explorers.
The 351 Windsor engine would provide more power but I've read that the deck height is larger to accommodate the engine's longer stroke. It might not fit in the engine compartment.
The stroked and bored 302 to 347 would be about as simple to install as the stock 302 except for a custom tune but is fairly expensive for an OHV engine.
The 4.6L came with the 4R70W in 3rd generation Explorers and I like the idea of a SOHC V8 with all of the chains and sprockets in the front of the engine. However, I've read that the engine is wider than the 5.0L (probably due to the heads) and may not fit.
What I would really like is one of the engines shown below.
However, the 4.6L DOHC V8 is even wider than the 4.6L SOHC V8.
