HighRoad
- February 13, 2008
- Oregon
- 98' Mounty/01' Sport Trac
Going to be looking for some help here as I just started pulling the 5.0 out of my 98' 5.0 mountaineer donor tonight.
A little background on my Trac. It is an 01' Job 2 that I bought from a kid in socal about a year ago. It started life in 01' by going to Offroad Mag. Here is a little history I have dug up..........
http://www.off-roadweb.com/tech/0608or_ford_explorer_sport_trac/viewall.html
http://www.off-roadweb.com/tech/0610or_2001_ford_explorer_sporttrac/viewall.html
http://www.off-roadweb.com/features/1006or_off_road_project_vehicles/viewall.html
The Trac changed hands a couple of time until I bought it. I reworked the rear suspension and put in a F62 Deaver pack and long travel shackles. It will get some 18" triple bypasses when the cab/bedcage is redone after the motor swap. Truck had 33's on it, and I moved up to 35's which required some trimming and moving of the washer fluid/overflow and also going to move the battery to the bed.
The plan: To build a street legal all purpose off road machine. I live on the Oregon dunes, so that is a given. Also setting the truck up for mild rock crawling like Rubicon/Fordyce/Dusy-Ershim etc.
Swap the 5.0/4R70W and put the BW4406 I have behind it.
Rebuild front suspension. I had some spindle uprights built that use ford dana 44 snouts/hubs and accept an RCV 30 spline stub. I am using RCV's outer dana 44 CV and probably will stick with the 930 inner cv's I have. Using a 10" coil over/bypass on the new a-arms.
The truck has a cab cage in it.........probably more dangerous than if it did not have one at all. This will get re-worked when the front suspension cage is done as well as the bed cage.
Stroke the 5.0 to 347/build the trans: I have a DSS racing 347 rotating assembly and am planning on rebuilding the trans with a Performance Automatic rebuild kit, hardened input, upgraded valve body, deep pan, and maybe a different TC with slightly higher stall, depends on the cam I go with on the motor rebuild. I have TM headers and will have to re-work the exhaust from there. Probably use Gt-40x heads to work well with the TM's..... Watching a couple of 94,95 cobra crank pulleys on ebay to get my 28oz crank triggered balancer/pulley set up. If anybody has a line on one for a reasonable price, I am looking.
Have a 9'' rear end that will go in when the front suspension changes to 5x5.5 bolt pattern.
I will be swapping the front differential for either an IFS 8.8 or a dana 44, or maybe a 9" center. Don't fully have this part figured out/engineered, but I need a good stout front differential that I can run a selectable locker in.
So, sorry for the long first post, but I wanted paint a picture of what I am headed for. I have been collecting parts for several years as originally the parts were all going into my Mountaineer. When I found the Trac, I decided to switch directions and build it instead.
Looking for advice on the stock Motor swap for now. Hoping ttbit and Ranger SVT will subscribe and lend their experience. Anybody else who has thoughts, please share.
Brent
