Recoil Rob
- April 5, 2008
- 2002 XLT
I purchased my 2002 Explorer new but since my 1991 was still running well it sat for quite a while at one point it was in a garage for 6 months. This caused the rotors to get rusty and prematurely wear out the brakes, my fault.
September of 2012 the truck was 10 years old with 23,500 miles and I redid all the brakes. The front rotors were salvageable so they were just cut. I had to replace the rears and got a set of Wearever's from Advance Auto. Also used Advance Auto DP Wearever Gold Pads all around.
Right now the truck is at 31,000 and the rear rotors are beginning to develop some serious glazing and pits again, the recut OEM fronts are fine. If it was just one rear I would imagine a stuck caliper piston but both are in the same condition.
Cheap rotors? Return them to Advance? I not feel like going through the entire job again but if I have to I have to.
Some pics of the damage and the final pic is one of the fronts which are doing fine.
Any advice appreciated.
FRONT ROTOR OK
FRONT ROTOR OK
