chrystal
- June 25, 2005
- essex uk
- 2000 North Face
Well decided that as I have had problems in the past, I should try a new seat base. Obviously this didn't work either! Then thought it might be the switch, because I know the seat is receiving power, its just not making the seat work. Then thought that if this doesn't work either, there must be a problem with the seat loom, so check this first, I saw that a green wire from the main seat connector (that connects to the connector from the floor) had a small bit or copper showing. so I stripped it all back and found what must be a previous bodge as I cant believe Ford would accept this. I have had the car from 3 years old and have not worked on the seat before.
Basically, there is a green wire that comes from the black main seat connector that then goes to the connector for the seat motors. Spliced into this is another green wire that goes to the switch on the side of the seat. From the point of the splice , both wires are burnt out. Pictures below:
The green connector goes to the switch on the side of the seat.
