Torsion bar twist? How Far? How High? | Ford Explorer Forums - Serious Explorations
cloud2or3
Burnaby, BC, Canada
97 Explorer Limited SOHC
1997 Explorer Limited V6 SOHC
I got some new shocks (KYB MonoMax) a couple months ago, everything was great for about a week, now I'm riding low - super low. Bottoming out over speed bumps etc. actually feel like a lowered car in the front lol.
So I ordered new replacement shocks - KYB MonoMax (again).
Not sure if that is the right direction, or if the torsion bars just need raising. Not sure how they would have lowered. Alignment was done BEFORE new shocks were installed, height was good. Had shocks installed, height wasnt adjusted, was great for a week, then I was on the ground practically in the front.
Hope that all makes sense...
My question - How much height is gained by 1 full turn of the torsion bolt? Going to try this method first before installing new shocks.
Shocks should have little or no effect on ride height with torsion bar suspensions. Did BOTH sides drop?
Be aware when adjusting the torsion bolts, camber and toe will change, and alignment should be checked.
Also, and if possible, take pics of the rubber bump stop clearance from the lower control arms on both sides.
Searched your past posts and saw the "Wonky Front Suspension" thread. IF you used Raybestos or Moog premium grade lower control arms for your front end rebuild, this thread regarding "slipping" torsion bars in loose fitting LCA hexes may be a possibility. Raybestos LCA pics are missing thanks to "third party" pics from PhotoBucket.
IFS Heavy Duty Upgrades! | Page 4 | Ford Explorer and Ford Ranger Forums - Serious Explorations
IFS Heavy Duty Upgrades! | Page 8 | Ford Explorer and Ford Ranger Forums - Serious Explorations
Yes, both sides dropped. And I know I'll be looking at another alignment post bolt adjustment.
Thanks so much for doing that extra footwork and searching my threads. YES, my hex holes are too big too! I've been telling every shop that I go to that this is my possibly the issue, and they keep saying "nope, impossible, no way that t-bar is rotating". I'm certain that is what is happening!
I'll post some pictures in a sec.
It's not so 'Fresh' right now but ignore the cleanliness lol. This pic it to show the ride height front and back.
Also, what are the chances that the torsion bars are worn compared to the Hex hole being too big on the LCA? Maybe our trucks need new TB's instead of new LCA's???
NICE truck and it looks great, what's wrong with that? JK, I'm lowered and love the look of moderately dropped trucks. LOL
Very possible your torsion bars are weakened, but they lose strength gradually, not like you describe in one week.
Hate to make you crawl on the ground, but could you snap pics of both LCA TB hexes from the front? Just curious.
Pics of hex...
Thanks for the good pics. Definitely loose, but doubt they could have slipped one flat. From reading past threads, 1995-97 used Kevlar pads bonded to the torsion keys that are known to wear out, but I don't believe worn pads would cause that much of a drop. At this point I'd remove both torsion key covers and carefully inspect. Bump stop clearance? What's baffling is it happened to both sides at the same time. Has to be something very obvious.
I had these installed...
Suspension Maxx Maxxcam adjustable keys
large
Just remembered you from this "ARC" thread years ago.
Who has dumped their ARC for regular shocks? Recommendations please... |
Did you convert your 1997 torsion key setup to use those adjustable Maxxcam keys designed for 1998-01 that uses insulator blocks with pockets? Something has obviously slipped or broken, but I'm not familiar with the older Kevlar torsion key arrangement. Again, what's puzzling is it happened to both sides at the same time. Maybe you should contact Don (CDW6212R) who helped you before with great advice, or hopefully he will be chiming in here.
Don's "insulator" pics in links below.
Torsion Bar Adjusters (kevlar pad replacement?) | Ford Explorer and Ford Ranger Forums - Serious Explorations
Torsion bar pads?? | Page 2 | Ford Explorer and Ford Ranger Forums - Serious Explorations
