Yeah, I had that once. I had to replace the left rear brake drum cylinder and my line was like that. I'm in Bemidji MN... typical road salt damage.
You can't do a compression fitting on line with that corrosion. It will never seal and you will crush the corroded line in the process... corroded brake line is very brittle. Compression fittings are bad practice on brake lines anyway.
So, you have to replace the entire line, which is actually an easy job once you figure out how to bend and flare brake line. Tools to cut and bend are cheap, you should be able to get a free rental of the flare kit from the parts store. They should be able to show you how to use the kit. You don't really have to make that tight S-turn, it just has to get from the wheel cylinder to the Tee on the differential in some reasonably neat way.
Odds and ends... you may find the fitting to the wheel cylinder is corroded so badly it just snaps off or crushes. If so, you will have to replace the wheel cylinder.
As you disconnect things, brake fluid will leak out. You have to stay on top of this. If the brake system drains completely, you will have to bleed the ABS unit, which is... you don't want to do that. So be prepared to make some make-shift plugs, and have lots of extra brake fluid on hand.
Now, the fittings on the wheel cylinder and the differential Tee are different. The way I approached this was to buy a long pre-made line which had the same fittings on both ends. So, I could use one end the way I bought it. I cut other fitting off and bought a fitting of the right size, cut the line to size, put the fitting on, bent it up, cut to size, flare the one end and installed it. Do not forget to put the fitting on before flaring it. This is obvious, yet I managed to forget it once. I don't know the fitting sizes, I went to O'Reilly's and they set me up.
Brake lines are not difficult or expensive. Buy some extra line and practice cuts, bends, and flares. When you get the hang of it, it's easy. That's a good thing because you probably have some sketchy brake lines in other locations. The line from the ABS unit to the rear runs inside the left frame rail, it tends to pick up snow and salt off the road, so it corrodes too. I ended replacing all the lines except the front right. But again, once you get the skills down, it's an easy job.
