Rear Brake Line Fittings Size | Ford Explorer Forums - Serious Explorations
massacre
Massachusetts
‘94 Explorer
‘19 Nautilus
Hello,
Is the muffler for the 94 XLT 4WD an offset in, center out?
Thanks.
Also the rear steel brake line passenger side is leaking at the junction block above the pumpkin.
Does anyone know the brake fitting size/pitch?
I can make the line but the fittings are not in great shape. And is it a double flare for the tubing?
I guess that is 3 questions, sorry
And thanks
I believe the muffler is center in and offset out but it has been a long time since I did a 94
Take your hard line off and take it to the parts store you can buy the correct line there and it should be available with proper fittings on both sides. I have not dealt with a drum brake rear axle brake line in a long long time but I have replaced them plenty over the years. Yes a simple double flare is needed at brake lines
The junction box itself is usually a part of the soft rear brake line so if you need a new splitter lookup a new rear brake line for a 94
Sorry couldn’t be more help but we got the ball rolling
Thanks for the helpful response! Much appreciated.
Just as a follow up-
The fittings for the rear brake hard lines are 3/8"-24
Just in case anyone else needs to know this
