Toddman41
- February 24, 2020
- Herculaneum, MO
- 2019, Explorer Limited
Installed some led highbeams to match the stock lowbeam leds, the oem halogen high beams were horrible and dim. These new replacement leds are 5x brighter... Much easier to see on dark poor lit roads at night. Link for led Highbeams... Amazon product ASIN B01MTJSLI5
Also installed a kenwood dashcam for piece of mind, used a rear view mirror to dash cam connecter converter from Amazon thatcame with a 6" micro usb cable for a clean install with no extra wire running. You simply unplug the wire harnessfrom the auto dimming rear view mirror, connect the new adapter to the oem harness, then plug the new adapter harness to the mirror. Last plug the 6" usbA end of the cable to the new mirror harness adapter, and the micro usb end to the dash cam. Came out great, and you can't see the camera positioned behind the mirror from the driver seat. Link to dashcam mirror connector... Amazon product ASIN B088P4VFQ7
