Nick26
- June 30, 2003
- Cumberland, RI
- 98' 5.0 XLT
Hey Everyone, I'm installing an Aussie locker but the 2 measurements i had to make were much tighter then they were supposed to be. One is the pinion shaft to the spacer clearance is supposed to be .006-.020 but in my case its too tight to even get the pinion shaft back in without jamming it. Then i had to measure the distance between the cam gears when done and it should have been .145-.175 but in my case was only .110. So the instructions say if these measurements don't fit then i need smaller thrust washers, but where do i get them? The ones i took out I measured to be about .042 wide. I called the dealer and the only dealership that has them is like an hour away and even still they just said they have the orginal ones not different size ones. Any help would be greatly appreciated. Thanks.
