- February 2, 2006
- North East Arkansas
- 2012 F150 4x4
I have been pondering a gear swap for some time now, and it is all finally coming together. I have been driving on my 32's and 3.73's for a while now, my fuel mileage and general driveability are suffering. Regearing to 4.10s will put me a touch deeper than stock with my 32's, and I can bump to 33's and be spot on. On down the line, I can run 35's with the 4.10's if I really want to, but it will be about like it is now.
My truck has 125k on it now, so it won't hurt to freshen up the axles while I'm at it.
For the rear-
I have a brand new set of Yukon 4.10 gears for my 8.8 on the way. I have a complete overhaul kit for my 8.8, new bearings, seals, everything. I also have an open carrier, Aussie locker and 3 quarts of Amsoil gear oil. I plan to rebuild and set up the rear end myself. It will come out from under the truck, be cleaned up, painted, rebuilt and set up over a day. (I hope)
For the front-
I have a used set of 4.10's, but found a third member at my salvage yard factory geared with 4.10's. It only has 40k on it. I bought and paid just a little more than what it would cost me to rebuild my third member. I figure since I don't have to set up the gears or rebuild it, I am way ahead. I cracked the cover the other day, the gear mesh is perfect, oil was pretty good, no shavings or anything. Buttoned it back up and refilled with oil. It's going to be a bolt in deal.
For the rear-
For the front-
