I dealt with my cruise being totally dead as well. The ford systems are a pain to deal with, since there is no built in diagnostics available, and not even a light to tell you its on or not.
First off, make sure the brake lights and horn are working. Then make sure the vac line is connected to the tree, and that the vacuum dump valve is working. Mine was misadjusted, so it was always open. On the servo, there is a hose that goes through the firewall down to a thing that looks like a pin switch that is mounted on the brake pedal assembly.
Pull the hose off on the servo, and either put a vaccum pump on it or suck on the end of the hose. If it is working properly, then it will hold vacuum or not let you suck air through it. If not, then it is defective or misadjusted. There is a black plastic thing mounted to the pedal shaft, and the valve can just be pressed down till it's making good contact with that and the pin is pushed in. It's one of those things that you must do by feel as you cannot both see and put your arm up there at the same time.
Next make sure the cable is not stuck, there are two screws on the servo that can be removed which will allow you to pull the cable away from the servo, this should open the throttle.
Wiring diagrams
Use the wiring diagrams and check for voltage and ground at the module, as well as for the resistances shown on the servo wires.
Switch Test
If you can track it down to one section of the system I can provide more info, it's too much of a pain to have to post up all of it. There should be a law that the service manual be included with the car lol.
-Ted
