medicbro2000
- December 7, 2004
- Ludlow Vermont
- (1994 XLT) 00 RangerXLT
hello!
I know there have been some previous posts around this type of topic...and I have read a good majority of them, however, I figured I would post my own in hopes of a response that would help me out..
I have a 2000 3.0 Ranger.... that has a rich smelling exhaust. I have had a bunch of parts replaced, MAF, Coil Pack, Some vac lines... but nothing seems to really change anything.
I have checked all the vac lines I can find and get my hands on, and even changed some that looked a bit bad. Still, I find the gas mileage is less than desireable, and it does have a bit of an 'idle roll'...
My concern is possibly a headgasket issue...which I cannot see any leaks anywhere and I do not smell antifreeze. It does not appear to be going into the oil either. My plugs and wires were changed about 2 years ago
I do have a bad Flex Fuel Sensor- Fuel compensation Sensor, which I really do not want to spend $600 for... I only found this out after my truck died and left me on the side of the road for a while. I got it running by unhooking the battery and then plugging it back in and it runs fine now with the exception of the CEL coming on... which gives the P0176 code which is for the Flex Fuel Sensor "malfunctioning".
ANYWAY- Could this be my problem??? Or does anyone else have any other suggestions that are less expensive that could be the answer? Bad Cat maybe?
Thanks guys!!
Thanks guys!!
