rocco123
- February 24, 2002
- Endicott, NY
- 1994 XLT & 2002 Limited
I have a 02 Limited 4.6 V8 explorer. Av Track off message displayed, Av track "disengage switch" would not turn it back on or off, & 4wd lo & hi lights on. Eng would rev, but wouldnt move in "drive" or reverse. When wife started to put it into park, it seems like gears were grinding. When I came home and ran it I had the same initial results, after shifting to drive & reverse it wouldn't move & would grind in park, but after going into drive & reverse & pushing the 4wd lo button it started to come around & now works OK. Could be something is wet? Pretty rainy here in Endicott Ny today.
I have added a ground strap to the tranny a few months ago as we are always getting the avtrack light, & thought it couldn't hurt getting a better ground. This is the 1st time an explorer had stuck us being unable to move.
Posted this several months ago in "Under the hood", and we still frequently get the av track off lights and 4x4 hi & lo flash 8 blinks every few minutes. but at least the truck moves. I have reset it several times by disconnecting pos terminal of batt & grounding, then ignition on & hit brake but problem still comes back. Innova 3160 & Autel US703 scanners would not show fault so I returned them.
