Hello to the group.
I have a 1996 Explorer with 250K kilometers. Today the battery light came on in the dash. The instruments also have a guage which indicates that the charging system is working. The battery tests OK with a tester which applies a load while testing. The tester also has a feature that tests the charging system- it tests OK. Multimeter tests on the battery terminals with the engine running is around 14.5 volts and 12.6 volts with the engine off.
Everything I have done so far indicates that the alternator and battery are both OK but the battery light is still on.
Any suggestions? Thanks in advance.
