Fire488
- September 7, 2010
- Monroe Township, New Jersey
- 2007 Explorer Limited V8
Hello guys (and gals), I have written about this issue in the past and I thought I had it cured, but apparently I did not. hang on for this ride....
I had a problem that started at about 60k and it was a miss that developed on the way home from a long, long drive. I removed the spark plugs and cleaned them checked the gap and threw them back in and the problem was gone. I purchased replacement plugs (Motorcraft) the very next morning threw them in and was good til about 80k when the engine started missing again.
I cleaned the plugs, re gapped them and threw them in and the problem was gone. I let it go till about 90k when the problem came back. I changed the plugs again and the problem was gone till about 115k. I replaced the plugs and the problem was gone. The problem came back at 125k and this time i replaced all the ignition coils and spark plugs once again. Now I am at 139k and after a 2 hours drive the problem has returned. I pulled the plugs and cleaned them although they were clean, cleaned the new coils and put them all back on and the problem is NOT going away anymore. Compression is good and even on all cylinders. No contamination in the oil or antifreeze. The plugs are clean as well.
I hooked up my crappy CanOBD2 meter and pulled the code for "random missfire". (P0300 Diagnostic Code - Random Misfire)
I am not sure what to check next as I do not have a diagnostic tool that can check "Mode 6".
Any advice would be greatly appreciated.
