chugbug
- April 4, 2016
- PA
- 2004 Sport-trac XLT
Hello all,
I did a search on this, but came up with a lot of varied posts from the last 12 years, so I'm hoping I might be able to get a fresh perspective on my issue. If there are some post that might be related, I'd appreciate the links. Anyway here's my issue...
I have a 2004 Sport-trac XLT with the 4.0 liter V6 SOHC engine and the 4.10 Limited Slip Axle option. I purchased the truck NEW in July 2004, but don't use it much-- it has less than 25,000 miles on it. Last summer I started to notice a chatter in the rear of the truck (something slipping) when I'd take off. If I pulled out very slowly, it wouldn't be as dramatic, or at all. It also seems worse when (the truck) is cold. After it warms up, it's not as bad. Then sometimes (usually when it's hot in summer) it doesn't do it all.
At first I thought it was low on transmission fluid, but I check that and it was fine. I had to take it in a few weeks ago (to the dealer) for a state inspection, do I ask them to check it out while it was in. The service manager called me and said it was either a) (get this!) the "break dust covers", or b) rings or shims in the rear end that need replaced, which was going to cost over $1,000 to repair.
I put the break dust covers on the truck when I first purchased it 12 years ago, so I said unless they didn't put the wheels back on correctly, It certainly wasn't those. But since that was his first "guess", I decided not to let THEM do ANY work until I got a second option. Maybe it was a legitimate idea, but I thought the dust covers answer was pretty lame. All he had to do was take the truck out for a ride and he would have realized it wasn't those. And THAT was the SERVICE MANAGER making the suggestions! Either simple or very bad-- no middle ground.
As you can guess, with less than 25,000 miles on a 12 year old truck (23,296 actual miles today), I don't use it much. Just an occasional trip to town or to tow my (small) boat a mile to the launch ramp in the summer. So I'm a little skeptical that it would be anything major, but I guess it could if you just go by the age of the truck. But if it was major, it would be a little upsetting at those miles (based on the national average of 12,000 miles a year, the truck spent 10 of the last 12 years just sitting in my garage!).
Anyone have any suggestions (other than to seek out a second (more thoughtful) opinion)? If you'd like any additional information, I'd be glad to submit it.
Thanks...chugbug
Thanks...chugbug
