Recently?
Umm how about last 6 months give or take?
-Dropped A4ld, replaced front pump seal and converter
-Cracked engine block at oil pressure sender (oops)
replaced engine with a loaner from a friend
-installed fiberglass fenders
-built custom new front suspension, cut and turned beams
-6" lift up front (with new beams, old setup was 3" spring and spacer)
-6" lift in teh back with new 4" leafs
-new aftermarket tranny pan
-Autofab tranny mount
-tranny temp gage
-33" tires
-rear disc brake master cylinder and new booster
-ARB compressor
-Sway bar disco's all 4 corners
-Rancho 9000's
-steering stabilizer
-custom axle shaft
-ceramic pads, all 4 corners, new rotors up front
-some body work, clear parking lamps
-relocated spare to where the back seat was
Next on list:
Sliders
custom front shock hoops
removable rear windows/soft windows
1/2 carpet, 1/2 Line x (Cargo area and rear seat)
35's
rear locker
roll bar/cage
