puzzaa
- October 9, 2016
- Maryland
- 2000 Explorer
Hey guys! I have a situation that may stump you!
So the other day I was driving and I heard a noise come from the back of the truck. Also at the time my gas gauge dropped to E. After some looking around I notice something fell inside of the tank! Could this be the float module?
Anyway around that time (not sure if they are related) but I now when I come to a stop the truck seems to stall (when I hit them hard the truck will stall, if not it just bogs down for a sec). The IAC seems to be doing its job because after I let off the brakes the truck seems to rev and lurch me forward a bit. I assumed my intake gasket leak had just gotten that bad that it was time to replace them. I replaced and still the same issue. Also checked brake booster line and no leaks there. Any help and if this is related to the gas issue?
Also not as related but my coolant temp sensor went out so I replaced that as well but now my gauge stays to C (I checked with a scanner and the computer is registering the coolant temp it’s just not showing on the dash). I double checked my wiring everything’s good!
Let me know if anyone has experienced this and thanks to any help!!
