Let us know if you need any help "via here", if you were close to me I'd be more then happy to come help in person. Good luck with the lift man.
Might as well replace them all since you're already taking out the bolts, JMO.
Failed due to a seized cab to frame mounting bolt and a deteriorated bushing
Any advice on this one???
I found a set of aftermarket daystar ones, trying to do the research to make sure they'll fit but it says 91-01 explorer and mine is an 01 but its a ST.
Just found out that the daystar kit is "bushings only" you would have to salvage your metal sleeves. Which in my case may be really hard to do, i thought they were pressed into the rubber bushing? Either way i may wing it at this point, this is holding up my project and i want everything done before the snow comes.
