I installed the HID's late last night/early this morning. My lights were fine before I installed them, but after took it all apart and put the new bulbs in,
1) I connected the relay to the battery.
2) I connected the power handling wire to the driver side headlight wire.
3) I connected the two smaller leads coming off the bulb to the ballast
4) I connected the ballast to the relay
5) Finally I connected what I assume is the wire that tells the bulb to switch between low and high.
What happens is, I turn my car on, and I turn my running lights on, and my fogs turn on. Then when I go to just turn my lights on low beams, my fogs cut off, and the high beam indicator comes on. Then when I toggle the multi function switch in either direction, the "highs" turn on, but the "lows" don't cut off, and here's the weird thing, the high beam indicator just gets brighter.
I'm really confused at this point...
