heffe2001
- August 25, 2009
- Conover, NC
- 2001 Explorer Sport Trac
I bought a 2001 Sport Trac a couple weeks ago, which had a factory flip cover on the bed. The locks that were on the cover weren't keyed the same as the car (I'm assuming it was from another car, and either the previous owner, or the dealer put it on there, but didn't get the locks changed). I had the locks re-keyed to the existing keys, but once I snapped it all back together, the cables appeared to be damaged (woudln't pull, even though the key moved fine, cables were indeed broken inside). I had noticed that the rear lock didn't have the spring-clip on the lock mechanism when I pulled it out (it was just stuck in there, you could push it out with your hand easily). I got my replacement cable mechanisms in today, which I thought also came with the locks/clips/etc, but only received the cable assemblies themselves, no locks/clips. I'm still needing a spring clip for the rear lock (it works, just moves up and down a bit, making it not so secure), as well as one of the rubber inserts to keep water out. Anybody know where to get those parts, or have the part #'s for them from a dealer? The cover works fine now (locks, unlocks, etc), just need those couple bits and I'm good..
Any help would be appreciated...
