DaveZyla
- April 19, 2022
- Crab Orchard
- 2001 Sport Trac
Have a 2001 Sport Trac with tranny issues. Aprox 30,000 miles ago I replaced the valve body, gasket plate, and solenoids which included the updates. Adjusted the bands at that time. It hasn't had any issues until this week. Shifts through all gears fine but if your cruising down the interstate above 2500rpms or roughly 71mph) it will slip out of overdrive- rev up to roughly 3500rpms. Sometimes it feels like it's searching for a good gear. If you let up off the gas it will shift back into overdrive until the next time however it's quite frequent. You can actually feel the "slip" just before it happens.
We were actually 4 hours from home when it started- checked fluids. Drove it home 4 hours at 2500 rpms with no slipping. OD light never flashed. Again it shifts through all gears ok and only has issues above 2500rpms.
Any thoughts? First thought would be a pressure loss Or torque converter but why above 2500?
First post here- thanks in advance
