'01 wiring harness schematic for towing lights. | Ford Explorer Forums
ambershnd
mpls,mn
'01 4wd
Where can I find out the color codes for my towing lights?
alldata or as we call it sumdata, and chiltons are the only 2 i can think of. have you tried googling it.
still looking
I'm new @ this & am looking for free help so its taking time to filter through everything
what kind truck is it? what year? engine size?
if i get some free time tomorrow I can look it up on alldata for you. its free where i go to school.
its a 2001 eddie bower edt. w/ 4wd 6.0
they didnt have any 6.0 engine sizes for a 2001 explorer. they were all v6 4.0s. Do you have the SOHC version, The SFI version, or the normal 4.0.
What specfically do you need? Color code for vehicle side? Your ex should have a harness tucked up under the vehicle on left side between tail light and license plate. It should be wired to there, all you should need is to connect to whichever type mating connector you'll use (4 wire flat or 5 wire round)
wire color codes for 2002 ford ranger towing lights
well i hooked up the wire trailer side. yellow is left turn signal/stop light... green is right turn signal/stop... (gray????) white is ground... but the gray is dead(3rd to the right)... "does the truck harness come with park lights for the trailer???" u know when u move the light switch in the cab be for u hit the head lights the park lights come on and stay on... "y wont the trailer park lights work????..." mine on the trailer don't work....
I have a 2002 ford ranger 2.3L... well i hooked up the wire trailer side. From left to right side. 1st wire yellow is left turn signal/stop light... 2nd green is right turn signal/stop... (3rd gray wire????) 4th wire white is ground... but the gray is dead(3rd to the right)... "does the truck harness come with park lights for the trailer???" u know when u move the light switch in the cab be for u hit the head lights the park lights come on and stay on... "y wont the trailer park lights work????..." mine on the trailer don't work.... Where can i get the color codes for my truck??? Please I'm losing hair fast.
Yes, the third pin is for the parking lights. You must turn the truck's running lights on before that pin will show any power.
