Jadecat
- August 16, 2016
- Findlay Ohio
- 2003 XLS
Hey gang. Got a question about the fuse block in my 03 Explorer. I am wanting to wire in an additional 12v power supply, cig lighter style, but I want it to only be hot when the key is on. I figured the easiest way to accomplish this would be to use an "add a circuit" fuse adapter and wire it to that. I already did this with a set a of LED DRL lights that I mounted and used an "add a circuit" adapter with the DRL fuse (#30 on the illustration below). I had to try a couple of different fuses that I assumed would only be hot with the key on (moonroof & radio), but they are, apparently, always hot. So I went with the DRL fuse.
So, my question is this, can anyone tell me which fuses, using the diagram below and the fuse number, would be only hot when the key is in the RUN position without me having to go through each fuse, while also not using a fuse that would be vital in case it would blow?
Just in case, this is the "add a circuit" I'm talking about
