lizzardtn
- May 25, 2013
- clarksville
- 2004 Ford Explorer
I have an 04 explorer with 159,000 miles. Pulled a small trailer for a friend. Drove fine the entire way. Went to start my truck and drive off. Now it doesn't want to shift out of first gear. Under real hard accelaration, then let off put it in neutral. It will shift out, then the O/D light started flashing. I have spent several hours researching after I found this forum. But they all describe different circumstances. Can someone please help limited budget, and don't want to just throw money at it or take it to a shop.
Drive normal, doesn't want to shift and trans seems to slip.
Drive hard in 1st gear, let off and then it will shift out after manually shifting from1st to 2nd
Plan on checking fluid now just in case(praying this is it)
Will update if it is
