Cebic
- March 2, 2014
- Dener, CO
- 2004 Ford Explorer
Hi! I am hoping you guys can help me with a couple of problems.
1) My 2004 Ford Explorer with a 4WD, V6 Engine and a Rebuilt Transmission from a 2005 Mountaineer will not allow me to backup. When I put it in R, the transmission does not engage. When I put it in N and let off the brake, the Ford moves forward. If I put in the car in Neutral with the engine off, the car won't budge, apparently the transmission is still engaged. I am trying to figure out how to get it out of my garage. There is not room to move forward. Does anyone know if there is a way to force the Ford into Neutral, so I can at least push it out?
2) The cool thing is a found a post on YouTube that describes the problem I am having perfectly. The fix, while not cheap is to much lower than installing a rebuilt transmission or rebuilding again the one in the SUV today. I have put the link below and the post on YouTube is called "Loss of reverse in your Ford transmission 4R44E/4R55E" If you don't want to look at that, I will paraphrase here that the issue is the band around the Low Reverse Drum has failed and need to be replaced. He quote a cost around $1,200. Does anyone know a good transmission shop in the Greater Denver area that I can use hat would be willing to try this instead of just defaulting to a rebuild?
http://youtu.be/2wiN8MV278A
Thanks for you time and consideration!
