coolwwebb
- January 30, 2013
- ottwaw
- 2004 Ford Explorer xlt
Ok here we go, I have a 2004 Ford Explorer XLT, I replaced the battery cause the old one start to die on me many time, after replacing the battery the truck wont start, I have a error code B1601, PATS received incorrect key-code from ignition key transponder. I have try both key both wont work, I check the ECU and it say I have 3 programmed key. The red light on the dash flash very fast when turning the key on.
I have checked all fuse, relay, and still wont work. checked starter and turn no problem when bypassing the starter relay.
any one can help what will be next to try it out, cause will prefers fix the truck my self then the dealer. ANY HELP WILL BE VERY APPRECIATED.
Thank you in advance.
David
David
