04 Ford sport trac wiring harness help | Ford Explorer Forums
fordtoughdee
Ladson sc
2004 Ford explorer sport
My ex knows I love my truck and of course he cut 10 of the wires in my wiring harness underneath the kick door trim (driver rear) well me being smart cut the rest to make the other ten reach one another. My truck runs like **** now 🤦🏻‍♀️ is there a way to remove that section and replace if so does anyone have a part number and if not does anyone have the color code and know the resistance of the ones that are the same color and stripe
Oh snap that stinks
Harness can be removed yes but need to pull seats and interior floor
That harness can be fixed but joints should be quality (solder heat shrink etc)
I had someone cut a module harness to take the module from my freightliner, I learned about solder splices from the dealer. Strip the wire and crimp them on, there's a clear sleeve you slide on first, then center after crimping. Use a heat gun to melt the solder inside. I used heat shrink over that for extra protection.
These are what I use
Developed by the military for aircraft and submarines I go through these things like they were water
I use the red and green sizes the most
You can buy just one size or variety pack
Ones I use are similar but have a barrel the wires go in which also has solder on it.
