Saik
- August 30, 2011
- 2004 Ford Explorer XLT
So for a week now I noticed my 04 Explorer 4.0L. Randomly tries to stall while driving or idle. Basically the rpm randomly drops low, and revs back up and down as if it wants to stall. When I press on the gas pedal while this is happening it usually has a delay, or the explorer shuts off completely.
Weird thing is this happens randomly very rarely. Usually when I've been driving for atleast 4-5 hours straight.
The engine has been rebuilt since I had a timing chain failure a year ago, and is running pretty good. No codes pop up, throttle body is clean as a whistle, and EGR was also replaced during the rebuild.
However how do you clean the EGR? Could it be a IAC issue?
Update:
Car now throws a code, and the stalling is even WORSE than ever.
Code is P0193
Possible Fuel pressure problem, or problem with the sensor.
Car stalls when it's warm. Basically it starts surging before dieing out.
Update:
Code is P0193
