-reverb-
- March 13, 2014
- 2004 Ranger Edge 3.0
Hi,
I recently purchased a 04 Ranger with the 3.0 with 180K miles. The trans is a 5R55 - not sure of the suffix. After driving a week or so, I started to feel the trans jump out of OD to lower gears under very light pedal. This usually happened at around town at ~40 mph or so. The tach would jump from 1500 to around 2300 and then quickly would settle back down and shift back into OD. It doesn't do this all the time, in fact most times it is fine. As far as the shifts themselves, they are smooth and consistent. In other words, when it is not showing it's butt, the trans is silky smooth. I figured a sensor or something was acting up.
I took it to a very reputable local trans shop for diagnosis. The told me there were brass shavings in the pan and it needed a rebuild. Upon return I was told the OD planetary had problems and they changed that and did a full rebuild - all wear parts replaced.
Took it home and a day or two later, it started doing the same thing - jumping out of OD then settling back in.
Took it back to the trans shop and they said "must be a pressure drop in the valve body". Worked the VB for a couple of days only to find there was not problem in there. Next idea was that the Power Control Module needed replacing. They changed the PCM and I picked-up the truck. All this work was done as warranty repair - didn't cost me any extra.
Now after a few days back with the truck, it's doing the same thing still - jumping our of OD and the quickly settling back in to OD.
To me, it's like the trans getting a bad signal from a faulty sensor, loose connection, broke wire or something. Given that it acts normal most of the time and the shifts are so smooth, I have a hard time believing there is a problem with the mechanical aspect of the trans.
I know this is a lengthy first post and I appreciate anyone's wisdom and advice on this matter. Quite frankly I am tired of dealing with this guy at the trans shop. His work is top-notch according to reviews but I just don't like his attitude towards me as a customer. He gives me the impression that he is "doing me a favor" by fixing a transmission that I paid him to fix!
Anything I can test/look at/swap-out that may solve this issue?
Thanks!
Thanks!
