08 Rear Camber | Ford Explorer Forums
08 Rear Camber
jrwendell
Houston, Texas
2008 XLT 2WD 4.0L
I have a 08 XLT 2WD, and the rear camber is way out out of spec. The place that did the alignment said, they are not sure how to correct it. After searching for a number of hours, I haven't been able to find any rear camber kits that work for an 08.
There has to be a solution.
You need to find a local alignment guru. Maybe someone who specializes in hot rods and the like. My wife's '05 Lincoln LS had the same issue. It was wearing the inside of the rear tires. As it turns out, at least for the Lincoln, there was no factory adjustment, or kit for the rear independent suspension.
I was fortunate that I already new such a guru in my area (Vancouver WA). He was familiar with this situation and actually made the rear end adjustable. It cost a little less than the price of a new set of tires.
