10" rear brakes on a 94 ranger | Ford Explorer Forums
triplexplorer
Littleton,Colorado
94 XLT
i did my rear brakes last night (which sucked to do btw) now i need to know how close do i need to adjust the shoes to the drum. i made them to where they are a hair from touching the drums is this correct. Also i have a 94 x i'm about to do this on. is it the same process? Thanks.
you actually want them touching, it is not the distance to the drum from the show but it is how tight they are. Basically you spint the tire (with tire off the groun) and adjust the wheel cylinder from behind until the wheel will stop in about 1 full rotation after you spin it
I Thought they were self adjusting??
they are self adjusting... but after changing them you are supposed to adjust them to be close, and with the same pressure on both sides, then drive backwards and stop a couple times and that should get them self adjusted
If y'all need I can copy the adjustment procedures out of my chiltons... I would be surprised if they werent already on here somewhere.
Self adjusting/adjuster.........be sure the threads are clean.
DRUM BRAKES
Drum brakes employ two brake shoes mounted on a stationary backing plate. These shoes are positioned inside a circular drum which rotates with the wheel assembly. The shoes are held in place by springs. This allows them to slide toward the drums (when they are applied) while keeping the linings and drums in alignment. The shoes are actuated by a wheel cylinder which is mounted at the top of the backing plate. When the brakes are applied, hydraulic pressure forces the wheel cylinder's actuating links outward. Since these links bear directly against the top of the brake shoes, the tops of the shoes are then forced against the inner side of the drum. This action forces the bottoms of the two shoes to contact the brake drum by rotating the entire assembly slightly (known as servo action). When pressure within the wheel cylinder is relaxed, return springs pull the shoes back away from the drum.
Most modern drum brakes are designed to self-adjust themselves during application when the vehicle is moving in reverse. This motion causes both shoes to rotate very slightly with the drum, rocking an adjusting lever, thereby causing rotation of the adjusting screw. Some drum brake systems are designed to self-adjust during application whenever the brakes are applied. This on-board adjustment system reduces the need for maintenance adjustments and keeps both the brake function and pedal feel satisfactory.
Aloha, Mark
