Texplorer
- November 20, 2001
- Morgantown, WV
- 96 XLT 4x4 4.0
Now that I passed the 100K mile mark I need to do some work on the X. I have made a list of things Im sure I need to do but I was wondering if I missed anything else. If you can think of anything I missed or anything you think I need to check or change please let me know.
Inspect/replace underhood hoses
Check/adjust drivebelt
Inspect/Lubricate Auto Trans shift linkage
Chassis Lube
Flush Auto Trans Fluid and replace filter
Change both Diffs fluid
Change Transfer case fluid
Check/Replace PCV valve
Check/Clean fuel system
Drain, Flush, and Refill Cooling system
Inspect/Change Brakes & Lube Caliper Friction Points
Change Spark Plugs and Wires
Lube Driveshaft Slip Yokes
Check Replace Fuel Filter
Already changed motor oil and rotated tires
Chassis Lube
