1350 slip yoke to 1354 flange | Ford Explorer Forums
newstylecustoms
Clayton, IN
199 Explorer Sport
Can I install an output shaft from a 1354 to convert my 1350 to a flange? If so will the same seal work.
Thanks in advance.
Anyone?
I already posted this on the drivetrain forum with no resonse anyone here know?
Thanks in advance.
probably not, but I have no idea. :D
no...just get the whole 1354 case...
Nope.
Thanks for the detailed reply.
I don't have any experience with this but I am converting my 2wd to 4wd and have the front driveshaft from a 94 Ranger and a Tcase from an older ranger (1350) and it seems to me that the bolt on flange would five less problems off road than the slip yoke on the 1350. Please correct me if I am wrong.
you are correct
hows this... the 1354 has a larger rear tail housing, a larger output shaft, different sized gears, and is about an inch shorter...get the whole case...
