- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
15x10 or 15x8? with 33x12.5
OKay I am finally getting ready to mount up my 33's, in order to do this I need some wheels.
My questions is I know alot of Ranger and Explorer people go with 15x8" rims with 12.5 wide tires, this protects the rim because the tire bubbles out alot on the sides, however I have also heard that I would be running 15# of tire pressure with this setup. I am concerned about tread wear and driving on the street.
Now I know the 15x10" rim is the preferred wheel if you ask tire guys or guys at the local 4x4 shops...
Of course backspacing is a big issue on the 4x4 TTB trucks beacuse you want to clear the radius arm, fender, etc......
Most likely I will be getting the Mickey Thompson Classic II rims with the standard backspacing. Clearance on my truck shouldnt be an issue because I have the Skyjacker radius arms that are curved, and AutoFAb 3" front glass, with a 5" lift coil up front.
In the rear I will be running Duff urethane cut out flares with my skyjacker 4" leafs.
What width rim do you prefer and why, 8" or 10" with the 33x12.5.......?
Thanks for any help.....
