MikeCol
- June 4, 2016
- Morton, IL
- 1950 F1 Ford Pickup
Still not a perfect gap, but way better than factory at this point. I just need to drill some bolt holes and pull it all together nice and right and this will look like a Chip Foose fender gap. BTW, yes, the F-1 emblem is upside down but that is how it was when we found the truck and I plan to leave it that way.
This is the inner fender mount to connect the Explorer inner fender arms to the cab. This picture was taken by sticking my camera under the fender and snapping a pic. The red part is the cab, the rusty part is the underside of the fender, and the green/grey is the explorer inner fender area. This is looking from the front of the truck towards the back of the truck. The multiple bolt holes in the square stock I used were every helpful to get the height adjusted correctly. I am doing rough fabrication at this point so once everything fits right, I will take it all back apart and clean up the metal cuts and weld things together to the fit and finish are nice and pretty, even under the fenders.
This is the passenger side inner fender. I need to find a smaller radiator and washer fluid reservoirs (see the white plastic reservoirs under the fender lip) to use because these are just too big to ever be used under this fender. I would need to remove the fender just to fill my washer fluid! Ideas welcome!
