Intermittent, rear brake sticking. Yesterday Front left disc started to pull, and smoke. ??????????
Happens with old age. Sounds like it's time to rebuild, or replace the wheel cylinders and calipers. Sticky caliper slide pins could also be the culprit: http://www.explorer4x4.com/tips2.html#caliper I would replace the drum brake hardware at the same time. It's cheap, and will give you all new springs.
yep pretty much, sound like a brake job is in order, not to hard to rebuild your calipers either. rear might need new wheel cylinders but that isn't rocket science either. good luck
