1993 Explorer with 2 inch BL (how big of tires) | Ford Explorer Forums
Retardriot427
Lynchburg, VA
1993 Explorer
hey everyone, ive got a 1993 explorer. Im puting a Performance Accessories 2 inch body lift on it. The question i have is...Im going to put new tires on it too. Im looking at BFGoodrich All-Terrain T/A KO Tires. Of the sizes they have, what are the largest ones i can fit without having to trim AFTER i install the 2 inch BL
You should have no problem clearing 31x10.5's (you will get a slight rub with the wheel cranked if you are running stock wheels, but its only the sway bar and won't hurt a thing). If you are running aftermarket wheels with less offset than stock you might be able to fit 32x11.5's.
my stocker clears 31s with no rubbing.... but than again, i removed my plastic wheelwells and the swaybars.... if only a 2" bl i wouldnt go bigger than a 31
thanks guys for the answers, with my 2 inch BL could i get it (by shaving a little) to not rub at all?
also, if i were to remove my swaybar....how would it affect the car.
