Scorpius68
- April 4, 2019
- 1993 Ford Explorer
Few questions on items I’m having issues with.
1. Front lights on the side (amber) are burned out, manual says remove top two screws and pull out the trim. It does not pull out. Am i missing something? I can’t seem to find where else it may be connected.
2. Instrument panel. I find nothing that is explorer specific on getting this bad boy out. I removed the trim around it, removed the lower trim, then removed 4 bolts from the panel. Doesn’t budge more than about 1/4 inch. Surely I’m missing something else. About half are burnt out and I’d really like to get to them.
3. Fog lights on the lower trim. Where is the switch for these or do they simply always turn on with the headlights? There are just two wires from the lights themselves and nothing more, i suppose someone pulled out that wiring so i may need to run a power and ground somewhere into a fuse box would be my guess.
4. When the rear is opened, is there no lighting that should turn on? Noticed it tonight pitch dark, opened and no lighting turned on. Didn’t readily see any switch to check. Only light i see is the internal dome light!
Any help on these would be great!
