1993 Sport Problem/Question? | Ford Explorer Forums
93exSD
Decatur, IN
'93 Explorer Sport
Hello,
Im new here so i'll go ahead and give you a little background. I have a 1993 Ex. Sport 5spd. In the last year ive done a full tune up, brakes(rotors & pads in front and shoes and hardware in rear). I just had a custom cat back single side flowmaster exhaust done. I used a rice burner adapter to make my cold air intake. Installed a 12" pioneer sub and JVC head unit. Ive replaced both o2 sensors. Converted to synthetic blend oil in the engine. Converted to royal purple full synthetic fluid in my tranny. Im going to go to royal purple full synthetic oil in my diffs and transfer case this summer. My problem is that ever since ive had the truck my check engine light comes on. The only codes it had were for the o2 sensor on the passenger side so i replaced both since i was doing it. And now After the truck warms up like 100% the check engine light comes. When i try to pull codes there is nothing stored. Also when it warms up it will run a little rough at idle. Nothing too bad but enough to know something is probably a little out of wack. Any more info needed i would be glad to give it. O and we are in really cold temps right now and we have like 12+ inches of snow on the ground so im trying to gather info for my spring fix up festival. HAHA. Thanks in advance.
Try pulling the wire of the IAC and see if it alters the behavior. The IAC is equivalent to a choke in a carbureted motor, so if it's acting up, it can affect idle and a/f ratios, which may cause it to toss a code.
