IAmTodd
4x Explorer Veteran
- April 8, 2002
- Johnstown, PA
- 2015 Jeep
So the time has come for me to part with my dear 1994 Explorer. Quick stats are :
XLT Trim
166,000 miles All work listed below has been done since 158,000 miles
4.0 V6 in great shape. New:
-All intake manifold and up gaskets [throttle body, injector seals, injection rail]
-All new EGR components
-Plugs + wires replaced
-Thermostat, hoses, and radiator
-Replaced fuel pump and level sender, new fuel filter
-Synthetic oil used while under my ownership
-Rear main seal has a small leak
M50D swap
-New clutch/master/slave
-New shifter bushings and top plate caps
-Proper manual ECU installed, uses all factory wiring/sensors
-Fresh Mercon fluid
-New trans mount in hand, just needs installed
Transfer case
-New shift motor
-Fresh fluid
Rear driveline
-New driveshaft U joints
-Rebuilt factory limited slip with extra clutches
-Fresh fluid
-new rear brake hardware (will need new linings for next inspection)
-Drivers side axle seal has a small leak
Front driveline
-Converted to manual locking hubs
-New bearings/races and brake linings within the last 2000 miles.
-New balljoint (Raybestos Pro Grade)
-New axle shaft U joints
-New diff seals
-Fresh fluid
-New spindle bearings and seals
-New radius arm bushings and crossmember
Lift
-2" spring spacers in front
-Full adjustable camber adjusters
-Rear add a leaf
-Warrior extended shackles
Tires
-Brand new Cooper Discover M+S 265/75R15 on OEM saw blade wheels
Interior
-Dual heated/powered Limited seats
-Factory sunroof (works, no leaks)
-Carpets are in good shape
-All heat functions work, AC system has been removed
-JBL Sub box, sub, and amp
-Keyless entry
-Overhead console, auto dimming mirror, and homelink visors installed
Installed accessories
-Diamond cuts headlights and corners
-KC Daylighters
-F-150 Tow hooks
-Thule roof rack
-Taillight guards
-Receiver hitch + trailer wiring
I'm sure there are many things I've missed but this is the bulk of the work done to the truck. It has been a great truck, both on and offroad but I've bought a new SUV and don't have a use for two. A lot of the work has been documented in my registry which is linked in my sig.
The EF price is $3000(well over $4000 in receipts) or best offer. It is located in Johnstown, PA
XLT Trim
M50D swap
-Fresh Mercon fluid
Transfer case
-New shift motor
-Fresh fluid
Rear driveline
-Fresh fluid
Front driveline
-New diff seals
-Fresh fluid
Lift
-Rear add a leaf
Tires
Interior
-Keyless entry
-KC Daylighters
-F-150 Tow hooks
-Thule roof rack
-Taillight guards
