prince402
- December 12, 2011
- South Florida
- 1994 Eddie Bauer
There is a rectangular channel running the width of the windshield just in front of it and under the trim strip. The windshield wiper pedestals drain into it as well as the fresh air intake vent forward of the windshield. The windshield wiper motor bolts onto the firewall side of this channel and the wiper actuator arms are in this channel.
On the firewall side of this channel there is a visible horizontal seam (weld line?) that is visibly seeping in a few places. I'm guessing that there is a seam also on the interior side of this channel that may be leaking into the footwells. The design is for the water to drain from the left and right ends of this channel down into the wheel wells. Access from the firewall into this channel is by removing two black cover plates but it is a very limited access. In what little that was visible through the firewall access panel at the far right, I found a rust hole about the size of a quarter and was able to get in there to patch that. I thought that maybe I had solved the problem but sadly it's still leaking, yes a little less, but still leaking.
I'm wondering if anyone has dealt with this problem and figured out a way of waterproofing this channel even with the limited access. The truck is otherwise in really, really good shape with good original paint and almost no body rust as a Florida truck. It's a shame that it is meeting its demise with this problem. I'm hoping someone may have an idea for solving this. I'm wondering if a long undercoat sprayer would be able to coat and waterproof his channel through the two access ports.
Firewall photos with right access panel removed.
