1Aauto
EF Vendor
- April 1, 2009
- mass
- 92 explorer
CHECK OUT OUR WEBSITE FOR CURRENT PRICING
1995 - 2001 Ford Explorer Control Arm Tie Rod End Ball Joint Kit
Is the steering on youR Ford Explorer or Mercury Mountaineer getting sloppy? Have you realized it's getting harder to keep your vehicle going in a straight line? If you've answered "yes" to either of these questions, it may be time for our steering linkage and suspension kit.
Components included as shown:
(2) Upper control arms with ball joints
(2) Lower ball joints
(2) Inner tie rod ends
(2) Outer tie rod ends
(2) Front sway bar links
Note: This kit is correct for vehicles with a 2 piece passenger side upper control arm only.
Remember whenever you are replacing any front end or steering components you should have your vehicle professionally aligned as soon as possible.
When installed correctly and an alignment performed, the components in this kit can also reduce uneven tire wear and in some cases you may even see a slight improvement in gas mileage!
FREE SHIPPING IN THE LOWER 48 STATES.NO HIDDEN PACKAGING FEES.
